Hi guys, I have this problem with zbrush 3.5, Ive been ignoring it up until now… ive searched for a solution but haven’t found anything…
When i move my model or rotate it around the screen fragments of the model seem to be rendered in space… i find it very annoying and would love to know the solution… thanks.
Which version of 3.5 are you running? You can tell by the left side of the title bar. Is it 3.5 or 3.5R2?
This happens in 3.5r2 as well, what i’ve noticed though is only if you use the buttons for moving or scaling, if you use the keyboard hotkeys this does not occur.
CTRL+N to clear the canvas gets rid of them.
3.5r2 has many display issues that hopefully will be dealt with.
aurick this has already been posted in the 3.5r2 thread on pages 8 and 9
thanks for the replys, and yes i do have 3.5r2… so theres no solid fix then i guess…
i think this is the same or atlease looks similar
i have the same problem in 3.5R2!!
but in the old 3.5 everything is fine, just R2 has this display issue.
Same problem for me.
I don´t know if I have 3.5 or 3.5R2, how can I tell the difference?
When I got the upgrade all I could see was 3.5 I have been wondering what this
3.5R2 is…
arepa3000- I think that is a whole different problem as that is 3.2 for mac…this is 3.5r2.
sion cross- I found one thing which seems to fix this and that is in preferences/performance turn off multidraw… this however makes moving the model around the screen a little rough… I myself just ignore it and use ctrl + N. do this and it clears the screen of the errors…(also first post in nearly 5 years…lol)
Husse- I suspect you have 3.5, you can check by looking at the very top left corner when in zbrush.
When I get that problem I move the modell around the window and kind of “sweep” the problem areas away.
Hexadecimator is not only on mac os:( i said on that thread it hapens on xp32 (64 too) what is not clear is the version but it hapend on 3.1 / 3.2 and 3.5r2 (3.5 too i guess)
