Of Course the other way is to build the body first and then select the area on the body teh jacket will cover and press the Extrude button on the subtools menu. Muck around with the settings a bit there too.
Snowkaren,
Unfortunately I’m workin on a Mac, and therefore ZBrush 2, so subtools are not an option. Thanks anyway! I can’t wait to get Z3 for that and many other reasons.
Dustbin,
Unfortunately I’m workin on a Mac, and therefore ZBrush 2, so subtools are not an option. Thanks anyway! I can’t wait to get Z3 for that and many other reasons. I’m going to try your suggestion, and I’ll let you know how that turns out. Right now I’m making my own Halloween mask (real sculpting involved!), so I am pretty swamped this month. Later!
Dave “Z” Wolf
Looks like you’ve used the Inflate brush to get those clothing edges. You could try using the Nudge brush to push polys from surrounding areas into these problem places. It should in theory maintain the shape of your model, while shifting points across the surface, but best results are only obtained from using this brush at very high subdivision levels.
You can increase poly density by subdividing a masked mesh, but be warned that this is likely to produce lumpy triangular poly pinching defects.
Instead, you might try hiding polys along those problem seams and adding edge loops to them.
Cheers,
R
Hello All!
So I was unable to finish my submission, but not due to laziness. On top of having a busy month at work, I had another project that I was already working on. I wanted to share it with you, so you understand why I didn’t finish.
I made my own Halloween mask, which involves actual sculpting …gasp! I was just starting to learn ZBrush, and I am going to still finish my original piece, and I promise this is not the last you heard from me.
Also, there are a lot of great entries, and I can’t wait to go through them all. Good luck to those that spent some real time on this!
Also, does anyone know when Z3 comes out for Mac? [attach=74810]Halloween Mask.jpg[/attach]
Here are some WIP 's of my mask, in case anyone was interested.
I was looking for your thread just now when I saw your picture up the top and clicked it and it took me here! Wierd!
anyhow, sorry you didn’t get finished, you made a great start.
The halloween outfit looks amazing! you look like you had fun with it.
You concept sketch was so good that it has inspired me to practice at drawing more. So alot of good from my point of view came from your entering into this comp.
maybe next time we’ll see your finished entry, I know if it’s half as good as your sketching, it’ll be amazing.
Laters! :D
