Scaling Issues Using GoZ vs Import .obj
I can’t be the only person who’s noticed that Zbrush has some real issues with scale. When made at default unreal scale (16 maya cm = 1 unreal foot) my models are enormous in zbrush. This wouldn’t be a problem, except that so many of zbrush’s tools are based off of it’s own internal scale, instead of the scale of the mesh. So when I GoZ a model from maya to Zbrush, the deformation tools, surface noise, transpose, dynamesh, and even some brushes control very poorly - or are completely unusable. What I noticed, though, is that this DOESN’T happen if I export an obj from maya, and then import the obj into zbrush. It only happens when I use GoZ. This is an incredible impediment to working with GoZ - which sucks, since GoZ is an amazing time-saver.
Are there any fixes / do the developers know this is a problem? I haven’t found anything from googling the problem except really kludgy solutions (mostly rescaling the model in zbrush). Please tell me there’s another way.
EDIT: Problem solved, this link has explanations and solutions
http://www.zbrushcentral.com/showthread.php?168239-Scaling-Issues-(GoZ-Blender-Max-etc-)-Solution-and-explanation&highlight=scale
