Hi all,
I’m trying to import and export between zbrush and free form and solid works. I’m having scaling issues.
I use the 3D print exporter and update model size and can export it to free form. Once there it’s off from my pivot point but sized correctly.
When I import it into zbrush however, it’s off in space at the wrong size.
My only solution I can figure is to import and export all subtools at once and use the 3d print exporter to keep model of original size and move the model to the floor center if needed.
Any help is appreciated.
