Hi
I know it is a common problem, but I can´t find the answert.
Created a sphere in MAX 30cm/30cm/30cm. Units are set to cm!
Used GoZ and the Sphere poped out in Zbrush. So far so good. Now I want to sclup on the sphere, but recognised the extreme small brushcircle. Even with DRAW SIZE set to 1000, it is way to small.
Gues it has something to do with units, but how can I switch units in Zbrush? It is not a problemsolver to use GENERIC UNITS in Max, because I use an anrchitectual environment set in cm.
Thanks for any help!
BR
Hilmar
