Saving SysPalette Custom Color Info?
Good morning all.
I was wondering if it is possible in Zbrush 3 to save the SysPalette color info? I’ve begun painting a model using the PixolPaint, which is marvelous, however when I left Zbrush and came back this morning the custom colors I chose while working were not saved in either the tool or documents I saved. Is there a way to save this info in the SysPalette menu? Otherwise I assume you would have to either take a screenshot or right down the color information manually for each custom color.
Thank you for your time,
JamesCG
Get this:
http://www.zbrushcentral.com/zbc/showthread.php?t=23194
And never worry about color palettes again :slight_smile:
Ghonma,
Many thanks! I had not checked out any Zbrush addons!
Thanks again,
JamesCG
