Saving project file (.zpr) and reference views aspect ratio
Hi there,
I’m using Zbrush 4R6 and have set up and stored a few reference views to use as a template for a head sculpt.
This works great however when I save the .zpr file and re-open it my reference views still work but they are now the wrong size and aspect ratio.
Is there any way of avoiding this so I don’t have to re-setup my reference views each time I open the project?
thanks,
alden
The aspect ratio shouldn’t change unless you are changing the document size for some reason (such as creating a new document).
I haven’t changed the doc size at all. It seems that the ref images are now stretched vertically. Any other ideas?
Can you let me have a project to test? The aspect ratio shouldn’t change as basically the plugin loads in an image the same dimensions as the document. I’ll PM you.
Thanks, PM’d you.
