Saving 'Preferences'
Hi.
I’m trying to save ‘Preferences’. When I set preferences and tap ‘Store Config’, everything ‘sticks’ except ‘MaxPolyPerMesh’. I set this to ‘18’ but it resets to ‘12’. Am I pushing too hard?
Here are my specs:
Dell Precision M6400 machine with:
Windows Vista Ultimate - Service Pak 1
5.9 Windows Experience Index
Intel ® Core ™ 2 Extreme CPU Q 9300 @ 2.53 GHz 2.54 Ghz
8.00 Ghz RAM
64-bit OS
Thanks!
~S.~
MaxPolysPerMesh has a maximum setting that will be saved. ZBrush will let you go above this setting on a per-session basis, but it won’t let you save a setting that is too high for your computer to reliably handle.
Thanks, Aurick! ~S.~
don’t forget you can make a startup macro that could have this change and whatever else you want.
