This question may be stupid to other but i have spent hours tryign to figure it out. I want to know how or if you can save your process in polypaint without converting it into a texture. OR do you have t opaint your mesh all in one sitting. When i save my file and come bck to it all the painting i had done is completely gone FML. Why?
CT
I’m not sure what your issue is…any Polypaint should save with the tool, as it is embedded in the polygons. Make sure “colorize” is pressed in the Texture menu of the tool section in order to see it, and make sure no texture is applied that might be obscuring it.
[Edit] An afterthought…do you understand the difference between saving a document and saving a tool?
When you’ve reloaded your model, make sure ‘Colorize’ is switched on in the Tool>Polypaint submenu.
