Saving a render with filters applied?
Hi everyone. I have rendered using BPR, and use several filters to get the look exactly like I want it. Is there any way to save out the BPR_Render.Psd with the filters applied? I save each pass and import them into Photoshop, but then have to try to recreate the look that the filters gave me. I know you can export the ZB document, but this is not the same resolution as the render passes…and therefore requires enlarging etc. Maybe I’m missing something…thanks for the help.
Document>Export is the one to use. The only time this will export a smaller image than the document pixel dimensions is if you have pressed the AA Half button. If you are unsure about this then just press the Actual button (or press 0 - zero - on the keyboard) before exporting.
