Runtime error using NoiseMaker
finally started playing with R3 and found that everytime I use the Noise Maker plugin
an error message shows up when closing ZB.Does not happen with the normal noise,
only whith the noise plugin.
For example:sculpting a polysphere,then open up the noise maker plugin -> choose
some noise ->clicking OK -> applying the noise then a BPR and then when I want to
close ZB the error message shows up,saying:
Microsoft Visual C++ Runtime Library
Runtime Error
Program:C:/Program Files(x86)/Pixologic/ZBrush R2/ZBrush.Exe
R 6025
-pure virtual function call
Then the usual message with 2 options,looking for a solution online or close the program.
OS is Windows7 64bit Home Premium
Edit: and although I was logged in already I had to log in a second time after clicking the
submit button.
