Rotating a body part
I can’t figure out how to rotate the arms and hands of a figure I made. I originally made this in Sculptris so I didn’t create this figure using the ZSphere’s so no built in armature to move stuff as needed. I want to see if I could make this into a poseable figure eventually to be used in other render programs but the hands are not in the “palms facing down” position and I really want to twist or rotate the forearms.
Any advice on how to achieve my desires?
Thanks kindly
Richard
http://pixologic.com/zclassroom/homeroom/lesson/transpose/
You’ll probably want to look into transpose master as well.
Now are those the Draw, Move, Scale and Rotate tools your referring too?? I tried to use the rotation tool and that was a complete bust. I’m sure I’m doing something wrong. I’ve always struggled getting my head around some of the tools in ZBrush!
Heya Ram, try investigating using a zsphere rig for posing meshes. Easy to use, and less destuctive then the transpose tools on thier own.
Thanks but the figure is already modeled so I don’t know if I can add a rig to it. Is there a way to do that??
Yes, you can add a zsphere rig after it is modeled. Check out the zbrush tutorials on pixologics main site under rigging.
Hmm, thanks, will do! :slight_smile:
Do you have a direct link available? I’ve searched around and can’t find anything specific to what you mentioned.
Thanks! :cool:
