im using the “rotate on Y axis” function and zswitcher so my viewport navigation is exactly like maya which im used to. The problem is that everytime i restart zbrush, the “rotate on Y axis” gets switched back to the zbrush default “rotate on all axes XYZ”.
I saved the custom ui config and set it as startup, saved document and project, saved hotkeys but it keeps switching back even when i open the same project where i had it on. Same behavior is with symmetry setting and the “menus” button at the top, all these get turned off everytime i restart zb. But for example “perspective” and “floor” keep their settings. I tried digging through menus, config files and registry but couldnt find anything relevant. I got all those functions hotkeyed but things would still be much smoother if i didnt have to think about ui stuff everytime i open projects. Also note that mentioned zswitcher has nothing to do with this, i tried everything with it off.
Is it somehow possible to make those settings stick? Mainly the Y camera rotation that is.
Any tips are welcome!
Win7 64, ZB4r2
