I tried rotating along different axes in Deformation, but I found it too coarse a control with the slider. Is it possible to rotate in small increments by some means beside the slider?
Thanks.
Thanks.
Left click on the slider, you will see the number box turn red. Enter numerical value. Numerical value is in degrees.
If you want to rotate on screen (rather than using deformation) then this may interest you:
http://www.zbrushcentral.com/showpost.php?p=854571&postcount=40
Excellent. Thankyou.
