Rotate brush Alpha's?
Is there just no way to do this, seems odd that you could move,scale but no rotate,
its really a pain to go into projectionMaster, use your alpha, pick up the projection master, rotate the model a little, drop back down inot projection master, repeat. thats really weird, you can rotate your stencils, why not brush alpha’s??
Do you mean when using them as masks?
No, like when you have a brush and you select your custom Alpha texture for it, go to projection mode and use the Drag DOt to position say a big wart or something you can move it around scale it, but you cant rotate it in 2d, does that make sense?
Have you tried using the directional brush and DragRect for your stroke in PM?
you can rotate your alphas very nicely with that inside of PM
AHHH thank you VERY helpful, its funny you can use Zbrush for so long and just get used to certain things then all of a sudden you find some new tool that deos something totally cool!
Thanks again you saved me alot of frustration!
heh yeah I love zbrush. I use it every day and every day I find something totally new that sometimes completely changes my workflow :slight_smile:
