Finally able to post work on the forum,
this is part of a robot I designed.
Thanks to Mahlikus The Black for the red material.
C&C welcome.
Base mesh in 3ds max, the rest in zbrush.
C&C welcome.
That’s very cool man. What’s you’re technique? Stencils or Masks? Either one, how do you do it?
Glad you think it is cool.
To create this I did not use stencils or masks.
I used Adobe Illustrator combined with Photoshop to create alphas. I used screen shots of my model to help draw my alphas to the right scale and orientation. This way they fit perfectly for this “Robot Part”.
I found Adobe Illustrator really helpful in creating custom
alphas. I also like using its gradients.
I made small parts such as screw heads in Max or ZBrush. These were eventually to projected onto the model using projection master.
Very cool, I can’t wait to see it textured.
Ok, so once you have you’re alpha’s do you use them as a displacement or do you use the inflate function or what? Thanks.
…friend!
Jettatore- I will try to prepare something that explains how I did it, I use the alphas for displacement by using projection master.
cmurray- I’m just leaving this as a sculpt for now, but a textured version would be interesting. Maybe I’ll post more
parts of the robot sometime.
Frenchy Pilou-
it does look kind of starwars like.
Hopefully when Zbrush 3 comes out I will beable to cut this Robot into more peices and assemble him in ZBrush
with more crisp detail. Maybe even to the billion polygonal level.
