RMB camera navigation issues
I love using the RMB navigation but it still has a lot of unrefined facets :
1- The RMB navigation the menu is useless as we have the Spacebar menu, and is annoyingly popping out when you don’t want it.So a disable option would be great in the Preferences menu.
2- RMB navigation it still behaves as it touches the model and it fixes the impact point as a camera orbiting pivot…this thing i presume it shouldn’t happen but is manageable …
3- Another annoying thing with RMB navigation is that when you use the Transpose tool, if you put the cursor on the model to RMB navigate , actually it moves the transpose tool and I think RMB should be completely neutral.Many times I found myself navigating with RMB while using transpose tool and I moved my subtool away without being aware of that (with Solo mode).
