Yes I have local transformations switched on, can’t even imagine working without them. With left click navigation, the pivot for camera rotation is where I last edited the model with brush as it should be. With right click navigation however, on top of that behaviour, the pivot for camera automatically changes if I use right click to rotate when cursor is hovering over a part of a subtool. That is not desired. I want pivot to stay where I last edited the model just like with left click navigation.
This entire thing makes the right click navigation pointless to me. The purpose of right click navigation is so that I do not have to get to the area outside of the model volume every single time I want to rotate camera. Currently however what I get instead with right click navigation is that I have to try to aim in areas around the model because if I won’t, the pivot for camera will get changed. It is serious problem when I am modeling a upper body for example and when I model side of the body I accidentally right click rotate on a arm and camera pivot changes, camera gets rotated in a weird fashion and I constantly have to readjust, breaking my flow.
So I simply want an option that disables pivot setting for right click when right click navigation is used. Left click already does that currently as it should anyway. I want to be able to simply prest right button and effortlessly rotate camera, without constant worrying where my cursor might be and if it is going to change my previously set pivot yet again.
On top of that, you have shift+alt+left as both sharpen brush and frame object. The only difference is that one is with tap and other with drag of the pen tip. Which means I constantly get auto frame and auto pivot problems. Literally every minute I have to readjust a camera because of those behaviours that seem to be nowhere in the preferences.
