Right-Click navigation and Folder paths
I have two questions/doubts:
1 - zbrush 3.5 and later came out with a new feature, that alow you to rotate the view in the canvas by pressing the right-click. I use the right-click to pop-up the quick menu, so how can I do to turn off the right-click for the view rotation?
2 - about the folder path, in Zbrush 3.5r3 when I want to import something, obj or alpha, or load tools, I need to look for the folder every time, what is annoying. Is there a way to set it to keep in the same folder that I used previously?
2 is in the Prefs. Turn off the “Use ZFolders” in the Misc section.
Not sure about #1.
Thanks Nick
still wondering about the right-click navigation
You can turn off right click navigation in preferences/interface :slight_smile:
Yes you can turn off the Right-Click Navigation in the Preferences>Interface. At the bottom of the menu.
Paul
Thank you guys, everything worked!
