Rigging
Hey guys,
Did you already try rigging with ZSpheres?
I mean, with this tutorial http://www.zbrush.info/docs/index.php/Rigging
Because, everything work perfect except third step (Preview your high-rez details on a posed mesh). When I set the Tool:Adaptive Skin:Density at the same number as model maximum have and hit the Preview with Shift button - my posed model is always in the base position (not posed).
Have somebody the same problem? What is the solve?
Thanks a lot.
Martin
weird this issue popping up in different threads with no real answer.
Guess riggin is just unpredictable that way
e1
Well you are posting in threads that don’t relate to the current version of zbrush. You could start your own thread if you have a problem with the latest version (3.5R3) and I’m sure someone could help you out rather than you hijacking irrelevant threads.
Richard
It’s an issue that’s been around since version 3 but is still there in 3.5.
Thanks for leading me away from “hi-jacking” this important thread and
if you actually had an answer to my question I would be even more grateful.
For anyone else unlucky enough to be struggling with this issue and who run
into thread trolls, here’s a 3.5 thread dealing with the same issue :
http://www.zbrushcentral.com/showthread.php?p=615073&highlight=rigging+preview#post615073
e1
My pleasure.
