I saw a video https://youtu.be/1oYQ6SRb8uI which used a revolve script I believe. Can anyone recreate this or direct me to where I can find it? Please and thanks.
Why don’t you just use the Curve Lathe brush?
I tried using it. Freehand tracing the edge of a 2d plane I made, similar to what they had in the video. Im not tracing it exactly as Id like. I end up with contours that aren’t straight, or round like they should be. Using the radial symmetry brush after wasn’t even centered the whole length of the obj. Exessive adjusting. I’d have alot less trouble if it just worked like it does in the video. I already have perfect geometry to work off as a base to revolve. I think the software could benefit from some basic line drawing tools. Lines, arcs, circles and ovals etc. With some handle bars for adjusting afterwards like some other softwares.
