Retopology workflow!!
Hi experts. I am confused about the modeling/retopology work flow in zbrush.
I sculpted a model with high details, then retopo it with clean edge loops. Now what? i’ll take the lowres adaptive model to other software for making its UV map, then bring back to zbrush, Can i have all my details back on a new UVed model (and maybe a little RE retopo obj model from 3ds max). I know there is an option “Projection” but its visible only when its in Retopology stage.
Sorry for my bad english, In simple words i want
Sculpt a hi detail model from zspheres method > Retopology my model with good edge loops > Export lowres model for UV > back to zb with new UV layout > Get All The Details I Did Before From Old High Detailed Model On New Uv mapped Model
Will be thankfull.
Good day.
Junaid
You’ll probably want to investigate the “Project All” button in the subtool palette.
:smiley: Thank you… yup, that was easy. I put both hi detail and low poly in subtool, clicked ProjectAll and YA :+1:, it project all the details on lower poly model.
Thanks again.
Good day.
Junaid
