retopology. unable to move certain points
So I’m retopologizing a model and I’ve noticed that I can’t move some of the points that I’m creating(not all, just a few)… This seems to be very random. anyone had this problem before?
Also, is there a way to get rid of the problem where the retopo wires keep disappearing every time I make a new point? It does appear when I move the viewport, but it’s kind of annoying.
Thanks!
you probably have a mask on.
ctrl + lmb drag a box off the model.
as to the display problem…only work around I know of is to rotate, like you’re doing.
You may need to turn Edit Topology off and then back on again.
