Hii Everybody, Can someone Help me out here?? Im retopologizing a character in Zbrush and This is the problem I have. BTW My name is Juan Pablo I’m new Here :o. I will appreciate your help. Thanks.
Not sure exactly what I’m looking at here, but based on the middle pic it looks like you’re having problems with projection quality? Try increasing the Dist slider in the Subtool> Projection menu.
If not, could you elaborate a bit more on exactly what you’re doing, and where the problem is coming in at?
I’m guessing you have more than 1 subtool showing and it may be confusing. Click the Solo button to see what your “active subtool” looks like.
Hey thanks guys!!! It was a projection problem not a retopology problem, Sorry. Anyways it was the Dist slider like you said Spyndel. The first photo its the topology that I’m using, The second one its the result i got and the Third one its how I did it. I put a mesh on top of the other select the one with the new topology and then hit project all. I’m I doing it wrong? It seem to work here’s a pic. I already play with the mouth but everything else its how i got it from the projection. BTW Sorry for my english and I really appreciated the help.
