Retopology Problem
I’m started retopologizing my model but I thought the zsphere was inside the mesh. I didn’t see it around the back. Now that I’ve started to remesh it, when I move the zsphere, it moves the new mesh. Is there a way around this or do I have to start again? Thanks.
did you append the zsphere as a subtool ? cuz you dont have too - never had that problem ! just select zsphere then rigging - select mesh then edit topology the sphere disapears leaving only a point which you can alt click too remove so you dont accidently use it in your topo - where as it looks like you just started topo maybe try this ?
I saw a guy append it in a video, but your way is better. I’ve since restarted and am progressing well. Thanks!
