Retopology problem
Hello I’m just starting off in Zbrush doing tutorials and I’m currently following this one http://www.zbrushcentral.com/attachment.php?attachmentid=61028 but I’m having a problem with the retopology step. I select the zsphere go rigging select the mesh and then select edit topology, but when I shift left click to paint over the mesh like the say nothing happens :frowning: If anyone could tell me how to do this, or point me to another tutorial about combining two meshes I would be very grateful thanks :slight_smile:
that feature was removed as far as I know. It would cause a lot of crashes before.
Ah, ok I found that using the clay brush you can just fill in the seam pretty well, and im sure I could learn the normal way of retopology thanks :slight_smile:
