Retopology problem
Hi my friends,
I get this message when trying to rebuild my model “please select a mesh with 15.000 points or less polygons”. My low poly has 44.000 active points becouse i deleted the lower level.
How do I fix this?
go to your lowest subD level
tool>geometry>reconstruct subdivisions
that should get your lowest subD back.
you may need to enable UVs
tool>UV Map>pick an unwrap type. any will work.
Goast666
Okay, I did as you told me but got no result. I received this message “Unable to reconstruct lower-level subdv. Operation canceled”
do you have triangles in the mesh? they will all go away when you create another subD level anyway…everything gets quaded during a subD.
Does you mesh have UV’s? is the option “delete UV’s” available in tool>uv map?
I dont have triangles and UVs in this model =/
okay, no tris.
do you have UVs? Sorry, your last post was vague to the UVs question
Sorry, ZBrush has the UVs option. I tried with and without UVs on my model and same response appears “Unable to reconstruct lower-level subdv. Operation canceled”.
do you have layers, a MT, HD sculpting, etc?
I really think I’d have to look at the mesh to determine the main problem. If you can upload it, I’ll take a look to see what I can see.
I’m tapped out on the usual errors that people have when reconstructing down. Some times mirroring the mesh will let it reconstruct…but I’ve only seen one mesh that needed to have that happen. So that probably isn’t it.
