Retopology - hide visibility of the retopo-cage on the backside of the mesh?(answered
Hi, is there a way to hide the visibility of the retopo-cage that sits on the backside of the mesh? It’s very confusing, retopologizing with the entire cage visible.
It seems like the original mesh itself is semi-transp, yet transp is off. I’m using Z4 btw.
  1. Turn off Ghost transparency if necessary. You may need to turn on Transparency in order to activate the button.
  2. Set the Preferences>Draw>Front Opacity slider to 1.
Thanks Marcus! Setting the front opacity to 1 did the trick.
Hi, How to remove a binding to the invisible side?
