I’m currently using Zbrush 3.5R3, windonw 7 64bit.
I retopology my sculptture and Zbrush makes weird surfaces.
Please help me.
Please help me.
Hey there,
basically your retopo is a little bit too low poly. As for the fingers you should try to retopo with at least 5 edges along the finger. Right now there are four and that is causing your problem. So just add another edge from the root to the tip of the finger and you should be ok.
Hope that helps.
P.S.: http://www.zbrushcentral.com/showthread.php?t=76364&highlight=retopo+finger
http://www.zbrushcentral.com/showthread.php?t=44876&page=32&pp=15&highlight=topology+flow
Thank you.
I appreciate your p.s. links especially.
