retopolgy problem
Hi, sorry my english,
im create a new topology from old model, but i have this problem:
how avoid this problem?
One of the Gnomology videos says that a toe or finger must be at least 5 sided cross sectioned to have proper rebuild of the mesh. It is the best, if you do it on the top or bottom side of the toe.
o, thanks.
I had the same problem in my Zbrush class. Like Jester said, zbrush cannot create an extrusion for a toe or a finger, so you just have to make another cut someplace on the top or side and make it 5 sided. Its weird, but fixed my problem.
thank you, but
i not completely understand, how is “you just have to make another cut someplace on the top or side and make it 5 sided”
sorry my english again, but can you to demonstrate with an example image?
I do find the topology tool helpful in Zbrush but this is when I export my base into Maya or Max and fix the problems.
