Retopo + Local Transoformations
I use local transformations when I do retopology because I’m working in such small areas. Problem is when I delete a zsphere point in the cage, the local transformations forgets itself and you have to touch the cage again by either moving a point or drawing new points.
Han anyone else come accross this? Thanks. It feels buggy, workflow wise.
It’s because Local acts off the last point edited, and when you delete a point then there’s nothing left to reference.
Doesn’t it work to just click on a different point to select that?
Yeah it works if I interactively touch the cage again, but I’m so in the habit of constantly rotating around the area I’m working on that I very often will go to make a slight rotation and it will throw my zoomed in work view way off because I forgot to touch the cage again after I deleted the last point.
It would be nice if the system would see a Delete action as an edit, so the local transformations would stay with you. I guess I just need to try to work that extra little step into my flow.
Thanks.
