Retopo - How to Align Verts
Hi
I have used zsphere to retopo a high-poly cylinder. As I did this by hand, the verts are a shakey. ( not in a line )
Is there a way I can straighten the verts ? I am used to Softimage where you select multiple verts and then scale them globally.
Hide the polys you do not wish to be affected and use the clip curve to shunt the verts into a straight line.
Hope that helps.
Thank you ! I don’t even know why that works, but it does. Google time :wink:
