Whats the deal with Zapplink v4?? I can only seem to get it to transfer my texture data from photoshop 1 or 2 times before it breaks? Better example, I export to PS make my changes save it like I have always done then re-enter Zbrush. It will appear to be projecting the texture onto the mesh and will start calculating and then poof its gone! It didnt project the texture onto the mesh, what gives here? This happens at random and I can only get Zapplink to actually project the texture maybe 2 times tops before it stops working? Any ideas? I would go back to 3.5 but Im unable to get Zapplink to even work in 3.5. Zapplink worked like a champ for me in 3.0, too bad I dont have that installed anymore =(. Any help would be appreciated.
wait, I figured it out. Apparently, ZappLink doesn’t like it when you export out with the Flat Color shader applied. Switched to a different shader and it seems to be working as advertised =).
