Rendering?
I am wondering if and how can you render inside ZBRUSH without using Maya? I know how to use the render settings in the render tab but how do you save out an image?
Thanks much!
Document>Export
For best results, create your document at double the desired size. After rendering, turn on the AAHalf button before you export.
Thank you! I have another question, I know u can change the background color but can u replace the black gradient to an image instead?
Thank u
import as a texture, choose flat material, do a crop and fill
Thank you, now correct me if I am wrong but I should be able to import my finished model with out that messing up the current material I have already painted on it? What I am trying to do is render a turntable of my model in ZBrush without a solid color or gradient background. I want to use an image of what i think would be its natural environment.
