Rendering question
I was wondering if there was anyway to anchor a sculpt along with all of it’s subtools while rendering - I keep having a problem where after the scene renders my sculpture will randomly rotate.
There’s 2 things you can do:
  1. Position your model and leave edit mode, pressing T. This will convert your model into pixols on the screen. Or:
  2. Position your model and create a marker, pressing M on the keyboard. Then even if you rotate your model, you can clear the canvas (Ctrl+N) and redraw the model at the same position, thanks to the marker.
Hope it helps, good luck.
