Hi
I am very new to Zbrush and so the solution to my problem may be quite simple. Thanks in advance!
I have recently install 4R7, which I am able to start and register, and the general functionality seems to work. However when I try to sculpt something it is rendered as weird triangles composed of lines in 2D.
Like I said, I am very new to this, so maybe this is just some option in the program that I need to change, but I feel it is more fundamental than that. I suspect I have some part of the installation missing or incomplete, but I have tried reinstalling it a few times. My machine is 64bit but I get the same problem with the 32bit installation.
Also, I am running it through wine on Linux, so that could cause problems. But the program seems to start well otherwise, so I guess there is some small part that is not right.
If you’ve seen this before I would like to know, and if you could point me in the right direction that would be well appreciated,
Thanks again
