Rendering movies from Zbrush 4r2b-4r3
How can I render my shadows and AO in the new versions of Zbrush 4r2b-4r3 for a movie? When I applied the flat material I use to be able to render out the shadows and AO separately no problem. Now when I switch to the flat material and render I just get the flat material with no shadows or AO. Is there somewhere to tell zbrush to render these passes? and yes I did enable the shadows through the render tab, but I must be missing something else.
Thanks,
Dave
I had that same problem in r3. I just hit bpr again and ao/shadow both worked. For some reason I cannot export movies though, something about missing dll
