rendering matcap in modo ?
hi
i really like the look of matcap gorilla but i would like to render my model in modo
so the question is is there any way to somehow bake the mat cap into my model without any lighting info & without loosing the properties of the matcap
for when i turned the light off to render, well i lost all detail naturally :slight_smile:
thanks for taking the time :smiley:
baking will certainly not work, as there is lighting already baked in. The backside has no (own) shading with matcaps. But you could try to write a realtime version of the matcap which shdnt be too hard really.
I’ve had some success replicating/creating Matcaps in Modo302 by placing gradients set to incidence angle on my objects, usually a ball to start with. You just have to play with the gradients for a bit. Modos interactive preview render is fast and accurate so it may not take to long to do.
Good luck.
