rendering and model help
please help,I am an illustrator, creating 2d images. Which is the best (easiest)
program to export my zbrush images too, in order to re-light and render at the best quailty. it is frustrating to create something that i can’t reproduce or use.
Also ,sometime i don’t have the time to sculpt a model .where can i buy/download a beautifully muscled figure from as a jump of place
many thanks
well, in my opinion for 2d images, photoshop should provide all the tools you might need.
Thanks for the reply
do you mean the 3d part of photoshop, because i want to light it as a 3d object.I haven’t got cs4 will it do it .
Thanks
So you want to render your 3D objects out, if i understand correctly. Well first don’t forget, that ZBrush has a powerful renderer by itself. It just takes a little trial and error.
If you want to use an external application, you probably don’t want to spend 1000’s of dollars, so i would recommend Blender (free), Modo or Lightwave.
Hope that helps.
