Hi
I wonder how and if you can render an image in a higher resolution than 72 dpi?
Hope someone can help me
Thanks in advance
Hi
Thanks in advance
All you need to do is set the document size to the pixel dimensions you need. So, for example if you want an image that is 15 inches x 20 inches at 300 ppi, you would need a ZBrush document of 4500 x 6000 pixels. You can resize the document in the document palette by turning off the Pro button, setting the height and width you want and pressing ‘Resize’.
