Render Help Please!!!! Solved!
Hi All
Just having a bit of an issue with trying to render a BPR with transparency… I set everything right as far as I can tell. Set the intersect on the sub tool I want transparent hit render but nothing happens, is as normal…Have no idea what I’m doing wrong.
Any help with this would be great thanks
You don’t use the intersect on the subtool anymore. Go to ‘Tool > Display Properties’ and turn on ‘BPR Transparent’ button.
Worked straight away cheers :slight_smile:
