I am new to zBrush, but I created a model and now need to render it out for print resolution (6000px x 4000px). How do I fit this into the window. Also, is there a way you can fix the camera angle and control the perspective?
In the Document menu, turn Pro off, set your dimensions, then click Resize button. Using the Zoom Document button on the right shelf, zoom out until you see the document edges. Load your model and using the Scale button on the right shelf, scale your model to fit. You can turn on Perspective and adjust the Focal Angle in the Draw menu.
Thank you. This was very helpful.:lol:
Bytheway, can you bring in an existing UV map with your object file into zBrush and then keep working with this using polypaint and later export it again with your model??
Your welcome! I’m glad you found my answer so amusing. :lol:
