Removing specific polygons?
Hello!
So I decided to use zbrush now for basically all the modelling. But I always run into one problem. I use the default human right now and I am modifying it to fit my needs. I want to convert his feet into shoes, but I can’t find a way how to efficiently remove his fingers. If I mask them and then use the “remove hidden” command, it really messes up the polys. If I use dynamesh, dynamesh then removes the fingers on his hands… How could I solve this?
Thank you :slight_smile:
