removing items from start-up
I’m to the point where I would like to streamline some of my interface. Theres many/most of the materials I will not use/do not need. If I remove them from the main ZB folder will that cause any problems? I can save them some where else If I ever need to put them back. Same with some of the brushes. And this goes 2x for the textures, I just dont have any uses for tem atm.
So, removing from the main folder will or will not cause problems with ZB? I’m thinling it wont, but thought I would check here first.
chris
The contents of the ZData folder should NEVER be modified. The things that you CAN do in terms of interface customization are explained in the first part of the online documentation. See my signature.
Well, at least I dont use Zbrush for production. My ill founded customizing has caused Zbrush to start behaving in unwanted ways. Lots of crashes while saving and an error message upon start-up thats says default Zscript cant be loaded…Does a complete reinstall require a deactivation and a new download link?
And by the way, thanks for your quick replies to my last few posts Aurick.
