Removing/adding background to zbrush model in photoshop?
Anyone have a “simple” tutorial they could point me to that explains how to remove the background of a zbrush render pass using the zbrush render pass mask? I did it a long time ago but can’t figure out how lol :frowning:
With the mask and color pass rendered, I load them both up in photoshop.
  1. Select the entire mask-pass document and copy it
  2. Switch to the color-pass, and with it’s layer selected add a layer mask.
  3. Select it’s layer mask, switch to the channels tab, make the layer channel visible/select it, and then paste the mask-pass into it
Thank you man :slight_smile:
