Hi
it is very timeconsuming, to render a huge image with sss just to test if the sss settings are ok. Is there a chance to render a region with the BPR?
Thanks in advance
Hilmar
Here’s the closest thing I know:
-Hold down ctrl and shift on your keyboard.
-Drag a box over the area you want to render.
This will hide all but the selected region of your model, allowing for a much faster render test.
If the render is still slower than desired, you can zoom out. The further out you zoom the faster the render will be. This may not be ideal for very many situations, but it can sometimes help.
Thanks for your reply. I did nearly the same. I have hidden all the subtools without sss and used a new document with a very small size. This helped a lot.
Thanks for your help.
BR
Hilmar
