When using reconstruct subdivision my UV islands are being welded together and I am unable to copy paste uV’s from an original clone object. Any ideas.
what are you doing that requires a reconstruct, and at what level did you unwrap your object?
Can you post a screen shoot? Reconstruct sub div is working fine for me. No UV’s being destroyed over here.
Good point. I done the UV’s at subdive 2 (turbo smooth in max) so thats probably why it was getting errors. I just went back and redone it from the base mesh.
P.S : I used subdiv 2 because turbo smooth normally stretches the UVs at the seems later on.
