I need some help… I have two hands, and somewhere along the way, the symmetry got screwed up… is there a way to make the hand on the left the same as the hand on the right? What a drag if not…
Mask the hand on the right to protect it. Then use Tool>Deformation>Smart ReSym to make the left hand match the right hand.
You’ll get best results if you start at level 1 and then reapply the deformation at each higher level.
Kickass! Thanks!
