I realize that I an new to ZBRUSH and I keep masking when I am simply trying to edit the topology. Is there a way to reassign the mask hot key to some other modifier.
Thanks
What about the possiblity of a dedicated topology tool that allows selection of multiple points in addition to adding and deleting.
The hotkey for any interface element can be assigned or changed by Ctrl+clicking on the element and then immediately pressing the hotkey that you’d like. The info bar will tell you what to do. Then of course you need to save the hotkeys through the Preferences palette.
However, certain ZBrush features do not have interface elements that they’re associated with. Those hotkeys are hard-coded into ZBrush and can’t currently be changed. Ctrl for masking is one such hotkey.
