hi people im new to zbrush and im in need of some help.
iv been doing this pic and im really stuck! i cant edit it now for some reason. can anybody help?
You’re going to need to start over, I’m afraid. You saved your work as a Document (using Document>Save As) rather than as a 3D model (using Tool>Save As). Documents are 2.5D, made up of pixols. Basically, they’re pictures with depth. To save your work as 3D you need to save and load it as a Tool instead.
Also, you don’t have to worry about blocking out that number in the upper left corner of your screenshot. It is not a serial number. It is preferable that you show that number when posting your screenshots. You will see a lot of screenshots on this forum with that number showing.
Or you can do File>Save As to keep everything you have going on in your tool pallet. Zbrush is quite confusing in how files are saved.
thanks for the help.
